Jwood
Just installed SolArk 15k and 12 pytes batteries. All is good except when trying to change the charge voltage settings. The integration guide for the pytes batteries says the Float voltage should be 55.6v and the settings for absorb and equalize (yes I know eq is not used) should be 56 volts. The SolArk (or the batteries) is locking the voltage for all three at 56.8. It won't change. What's interesting is that the battery information on the communication screen, (press the gear then LI-batt info on the SolArk) the SolArk shows on the battery info page that the charge voltage for the batteries is actually 56.8, even though it conflicts with the integration guide.
All the software is up to date, just wondering if anyone else has run into this, or been able to confirm which voltages are actually correct (integration guide, or what the locked voltage is). Also why it's locked at 56.8V
Thanks!
Thanks!
