Good Afternoon All,
Forgive me for my lack of experience here, I have just began researching for this project.
I have been working on this 1985 35' RV that was originally intended to be a Horse Coach with 6 horse stalls in the back. I have been working converting this rig to carry my 1978 Toyota FJ40. As you can see from the pictures there has been some headway made on the garage conversion front.
My latest focus is on the electrical side of things. When purchased the RV was setup with 2 Onan 4000 watt 120V generators along with 2 separate 30 amp RV panels and 2 separate 30A shore power setups. The RV was originally separated front and back with two breaker panels.
My ultimate goal here is to setup a 48v lithium house battery bank and a 120/240v inverter setup with solar on the roof. I would like to retain one of the generators and remove the second one. I would also like to be able to power the system on 120v shore/ generator power and still be able to invert up to 240v. I am starting from scratch here so I am open to any and all suggestions.
So far I have been considering the following setups to get started on the battery/inverter front:
- EG4 6000XP with a separate 48v 100a Chargeverter
- 2 x Victron Quattro 3KVA 120vac 48vdc units in a split phase configuration. I haven't found a lot of information about this but from what I have gathered it is possible to have a master and slave 120v unit and have the master provide 48v DC to the slave and have the slave provide the opposite phase of 120v power for a true 120/240 split setup.
- 1 x Victron Quattro or Multiplus 5KVA 120vac 48vdc with a Victron Autotransformer on the outlet to create the 120/240 split phase output.
As for the batteries I have been pondering picking up 4 ECO-WORTHY 48V 50Ah LiFePO4 Lithium Batteries to get started.
Now the goal is to be putting 3600W of solar on the roof of the RV later in the year. At first just run the batteries off the shore power charge and top off with the Generator along with a alternator power via 12v-48v BB124870 DC-DC charger I just purchased from Sterling Power.
Here's a rendering of the proposed solar setup on the roof:
These are 5 x Canadian solar BiHiKu7N-MB-AG 655 and then 6 optional eBay 100W panels just to see what else fit. I would start with the 4 BiHiKu7N-MB-AG 655 on the back.
How would you guys recommend I kick this off?
Thank you,
Mike
Thank you,
Mike
