stevies
Hi there,
BLUF: I would like the ability to toggle my battery automatically in to charging mode when my Tepeo or Mixergy turn on.
My setup is as follows: Tepeo central heating electric storage boiler (40KWh), Mixergy domestic hot water cylinder (~12KWh), Pylontech battery stack (20KWh useable), Solis hybrid inverter and 7KWp solar system. My setup gives me about 24hrs of total energy independence (soon more once better insulated) and I run on Octopus Agile, meaning I can pick and choose the cheapest 30min slots each day to charge.
The problem at present is that I have to manually set the Tepeo and battery charge times to overlap (to avoid the battery dumping charge into the Tepeo) based on each day’s charge slots and I currently just take the hit with the Mixergy drawing from the battery in auto mode. Both the Tepeo and Mixergy have algorithms to learn patterns of behaviour/heat loss/external conditions and read the agile tariff data to charge automatically at the cheapest times - I just want to piggyback off this and have my battery switch to charge mode whenever they draw power and back to auto when then don’t.
I’m not an electrician so please shoot me down, but could you put a CT clamp on the wires supplying the Tepeo and Mixergy, and use that data to trigger the inverter with some custom software? Or is there any other better way?
Appreciate any assistance.
Steve
Steve
