Gentleman Mike
Hi all, I'm having an issue with an SPH5048 from SGP. Their support is worthless and they send you on wild goose chases, so I'm wondering if anyone here may have any ideas on whether I've just done something wrong or if this unit is defective.
When on inverter power, on the AC output, I'm reading 25 VAC between neutral and ground and 96 VAC between line and ground. However it does read 120 VAC between line and neutral.
It also read 25 VAC between neutral and ground AS WELL AS line and ground on the AC input side, when I have grid power disconnected.
When grid power IS connected, I still read 25 VAC between neutral and ground and it turns out that this thing is constantly pulling 5-6 amps from the grid even when there's no load!
Something is clearly wrong. Any thoughts? Other than I should have bought a Victron?
