Oh, it will be ok, as long as you don't run any heavy loads on the inverter.I may upgrade at a later date. The wires and terminals can handle it. I don't plan on using big power but I had this welding cable on hand.
Keep in mind that thing can output 6500W, so if your bank is low, amps can exceed 135A fully loaded.
70A on #6 after losses, conversion etc and you have some seriously overloaded wiring.
FYI, #4 is needed to meet 70A ampacity.
And the wiring will heat at that load.
