TheWanderingJackalopes
- Mar 23, 2022
- 27
I just installed my electric power center for our RV conversion, and everything has gone great, except for one weird thing. The Growatt does not output 120v AC when running on just batteries and solar. It works fine when plugged into shore power. Everything else works. Batteries charge and output power, solar panels charge batteries, AC output works when AC shore power is applied (and likely from the generator as well).
There’s a reset button, which I assume is an AC breaker on the bottom of the unit. I’ve tried pressing it, nothing changes. The button on this breaker also feels very floppy. Is it supposed to be like that? That button being bad is one long shot possibility. The other, which I think is even more remote, is that my AC input goes through an automatic switch that flips between shore power and the generator. The switch only has connections for line and neutral. The ground wire (green) bypasses the switch and is wired to the ground bar on my panel. I did not run a green wire from the panel to the AC Input on the Growatt because the ground on the ac output is common with the ground on the ac input. it seems unnecessary. If I am wrong about this, tell me. Again, the ac output works when I have 120v ac input, I’m just not getting output from the inverter.
Is there anything else I should check?
