Thanks, I hadn't heard of the power triangle.
I'm really just looking for some confirmation from owners of this particular inverter, multiplus II 48/3000, or even victro owners in general that their published specs are accurate.
11watts idle
at 25c
3000va continuous
3900va 30 minutes
5500va 2 minutes
Watching some performance tests of this inverter online have called the published specs into question. The tester didn't disclose volt amps, rms amps, ambient temp or time at specific amp load, so you have to take that for what it's worth.
I'm not going to write off victron for a couple poor performance tests with incomplete data, hopefully someone here can provide a contrasting opinion.
I do have test data (watts, amps, volt amps, pf) for all of my appliances from a killawatt and ketotek power meter.
If I had a big party and ran everything at once I would need like 6kva, but 99% of the time I will be running just one or two appliances plus some base critical loads.
What I'm trying to do is model a few typical power usage/ambient temp scenarios on paper vs the published data from the inverter manufacturers so I can spec an appropriate inverter/inverters that meets my needs most of the time while limiting idle current. Since I'm mobile and don't have room for additional solar panels, I'm putting a high priority on low idle current and conversion efficiency.
11watts idle
at 25c
3000va continuous
3900va 30 minutes
5500va 2 minutes
