Okay, so I have a 24v LFP battery pack that I assembled a little while ago and I'm charging it right now. The battery prior to charging was reading roughly 27.2v. I connected it to the inverter charger to charge it up and the voltage on the battery went up pretty quickly as it was getting about 30 amps into it for charging. I've been watching it a little bit. It seemed that the voltage capped out about 27.6v and then the voltage has just been dropping. Which is totally not what I was expecting. I figured they would increase from the 27.2 to 27.5 or so and then slowly climb until the pack was fully charged at 29v since I need to do a proper top balance. But instead, I've seen the voltage drop from 27.65 to 27.3 even though it is receiving 30 amps from the charger. The inverter shows 30 amps in, the battery shunt shows 30 amps in, and the BMS also shows 30 amps in. So I have no explanation for why the voltage is dropping instead of increasing...
Ideas?
Ideas?
