sunshine_eggo
Happy Breffast!
I finally got the WizBang required and was wondering if my SOC will ever reach 100% when the batteries are under load? I got to 95% today with still plenty of sunlight left to charge the batteries or is the last 5% normally charged via the Float setting.
If you have more solar than loads, yes, but the shunt must be programmed and working properly.
I checked the manual, and I can't see the option to specify charge voltage and tail current, so I assume it must pull that from the Classic charge controller.
Do you have your charge termination criteria set correctly in your Classic? From the classic manual:
