Got the software working. I see similar to what somewhereinusa does... Running as a user, I see 5 tabs in the lower section, but cannot select a com port, thus the rest of the fields are blank. Running as administrator, I can select the com port, see data, and only have 3 tabs. I have a feeling this software was built for Win XP and the tighter security of things in \Program Files is creating problems. I may try to load this up on an XP machine I use for car diagnostics and see what happens.
Temp Sensors 5 and 6 are pulling numbers out of their butts. This screen shot was taken right after the SCC said the battery was full on the LiFePO4 charge profile. The Balance active button did come on during the charging cycle as well. I disconnected the computer from the battery and let it sit over night. When I hooked the computer back up, the cells were "balanced". I think it's safe to say the battery will balance on it's own.
It also appears that bank 2 is the weak one as it doesn't want to go above 3.429v during the charge cycle. The other battery I got also seems to have a weak cell. It doesn't go above 3.420v.
Up next, I'll hook up the inverter and run a load for a while to see how the battery does on the discharge side of things.
