I recently received a battery i purchased, 24v 300Ah, and I wanted to test it to make sure everything is working correctly and it actually has the capacity it’s supposed to have. I`ve been looking through the forum as well as online for a capacity tester for the entire battery (not individual cells) and it doesn’t seem like there is anything that is made for higher amperage, everything I find is for lower amperage, I don’t want to spend 24 hours . Does anyone know of any higher amp tester that works for a 24v battery?
The ones I found and looked at;
DL24EW
seems to allow to go up to 600w with 3 expansion boards - 600w/24v = 25A
CBA A2 500W
seems like a nice setup, a little costly but I’m planning on getting more batteries and having a good tool never hurts
option 3
build my own using a smaller 600w 24v inverter and a shunt (haven’t picked it out yet) would say it might cost me $150 range after all cables, shunt, inverter, etc.
Any thoughts or other suggestions?
DL24EW
CBA A2 500W
option 3
