Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 21,336
Makes sense your PV production is middle of the day. Actually peaks earlier than noon, is it SSE oriented?
Since you've got a battery, what you may want to do is recharge while PV is producing, discharge into the grid while rates are high.
Should be able to do that even in excess of loads, so you get credit at higher rate.
I haven't figured out the settings yet. Which vary with firmware revision. I have to stop at 1.50 in SBS, to support Resu-10H. Yours would work with newer firmware.
How about reports from SBS? Mine has a graph showing SoC during any given day.
