ricardocello
Watching and Learning
https://www.victronenergy.com/live/ve.bus:grid-codes-and-loss-of-mains-detectionurchase without knowing with the "other" grid code options are.
If you select other don't other options come up for you to tweak the settings?
Just LOM setting as far as I’ve seen.It's those other options I need to know about, if they exist
yeah I watched it twice and said hand me another beer..I re-watched it and felt a little less dumb.
So the question is will I need more hardware for lom detection in the USA?Just LOM setting as far as I’ve seen.
While “experimenting” with this ESS, I have determined that LOM B works just fine for me to detect outages.So the question is will I need more hardware for lom detection in the USA?
Hi. May I pm you for some additional information?thanksWhile “experimenting” with this ESS, I have determined that LOM B works just fine for me to detect outages.
Officially, I have a chargeverter to keep my batteries charged, no grid connection to inverters.
Bottom line here is that Victron is not UL listed, and will not be approved by POCO or AHJ..
Ok thanks. Just making sure that if I'm in the USA using a victron it won't backfeed the grid if the grid is downNo. It's automatic based on what's happening at AC Input 1.
Side note:
LOM exists even if ESS is not in use.
LOM detection can be annoying for users using grid as backup. They will set various criteria for "ignoring AC input". Once the criteria are met to ignore AC input, this will trigger LOM (mains are actually preset - they are just being ignored) alarm. Most prefer to disable LOM function in the cerbo to get rid of the error.
It's an enclosure for smartshunt and switch: the cover is slightly different more flattened to allow for easier printingSo this is a mounting spacer for the shunt and lynx? With some touch protection? Bit more fancy than some shims and acrylic.
there's a lot of Victron stuff on Thingverse
Oh no! ... I am now thinking about learning how to 3D print stuff. A new rabbit hole to dive into like I have done with solar stuff.an enclosure for smartshunt and switch:
