❓ TDT-BMS Wanted Feedback/Experience
I did!
I've change a new esp32 and uart-to-ttl, I think during my last connection I've burn the ttl converter, otherwise done!!!
Thank you so much.
Just the last one.., there is no switch entity CHG MOS and DSGg MOS ?
Thanks
Hi. This is how I use Wi-Fi for Home Assistant.It took a while, but the effect was very good. My BMS via the rs232 connector connected to the rs232 ttl to uart converter. And further to esp32. I converted the esp32 software from seplos-bms. Here's your software:
https://github.com/syssi/esphome-seplos-bms/issues/71 . Look for the comment from February 3. There is a tdt-bms.zip file there.
When in doubt, ask.
Thanks I will check it out. I have also noticed that after few cycles the FCC (Full charge capacity) is incrementing in one BMS and decrementing in another one . did you experienced anything like this
Currently the TDT6032 and TD6022 firmwares are OK. The BMS is fully functional even in parallel operation. The only problem I sometimes have is with the SOC calibration
did you get any solution for SOC problem. I also facing the same and reported to TDT
Yes, there is a problem with this. I wonder if it is necessary to calibrate the current, because it is used to calculate Ah.
When I have tested with JUNCTECH KG110F Battery Moniter, there is a small difference in the volt and Amp may be that cause this issue. per day its reducing about 2.5A in one bms
Hello, everyone,
finally I can see what's going on in my battery pack, I noticed that the cells are not aligned in voltage, in fact I mounted a 1A daly balancer, I noticed though that in the BT application of the BMS (Bms META) there are some setting values that I don't understand, could someone kindly explain me what they are?
Thanks for your time!!
Hello, everyone,
The BL threshold is when the balancer turns on so in your example any cell over 3400mV the balance function for that cell will be open.BL delta cell is the deviation or difference between cells which in your example is set at 30mV.The balancer will work to get all the cells within 30mV of each other
There is in the parameters a spot where you have Design Capacity,Full Capacity,Remain Capacity.Fully charge your battery dont worry about whether you charge to 3500mV or 3650mv just pick a mV,hopefully all you cells are decently balanced.When fully charged, Full Capacity is equal to Remain Capacity click W.Discharge the battery to a point your happy with 0% if you like but I dont like doing that.Charge your battery up and you will see your Remain Capacity climb up in Realtime Monitoring under DATA.When your battery is fully charged you will have a new Remain Capacity in Realtime Monitoring.Plug this value into Full Capcity and Remain Capacity in Parameters click W.If you have a real quality capacity tester like a ZKE that Andy uses in OFF GRID GARAGE you would just plug that capacity test value into Full Capacity and if fully charged Remain capacity would be the same and click W.IF not do what I did for a number of cycles and your SOC will become more accurate.So in my situation I have REAL QUALITY EV cells LF280K with like 314 or 315AH.So I guessed my Design Capacity was 300AH,Full Capacity 300AH and yeah I quessed that the remain capacity on my new cells was about 50%.When you charge it up the Remain Capacity will climb in my case it shot right past 300AH.Keep cycling keep plugging in the new values and click W and the Law of Averages will get you closer to your true SOC.Iam at about 314AH but it will come down a bit more but already Iam around the value of capacity for each of my cells.Not bad for a guess
And if you drain your battery to say 0% in my case since I guessed too high 315AH is dreaming you will still have some AH left in the tank but the battery is empty so say you still have 5AH (5000mAH) then 315-5=310AH and you could plug 310 for Full Capacity and 0 for Remain Capacity click W then charge battery up to fully charged and that value will be very close to your full capacity it might not be 310 it could be 310.5 or 309.3AH.You dont have to drain to 0% if you know the charging and discharging curve of LIFEPO4.There is very little capacity like 2% above 3500mV and below 2900mV maybe 2% this is negligible you want to keep your charging and discharging on the FLAT part of the curve.For me charge to 56V float at 55.2V or 3450mV per cell and discharge to 49 or 50V.I hope this helps
Now i am using inverter with can communication and after the latest firmware update it seems to be much better. Using 100Ah Highstar cells , Now I have changed the design capacity, FCC RM to 105Ah after charging to 56.8V and set 56.8V as pack full and Alam Voltage since its sending alam voltage as charge voltage from BMS. after few cycles now its showing 103Ah reaming at full charge and FCC will be around 104. in JUNTECH external shut it will show 99.1 to 98.5Ah when bms showing 100% SOC.
initially I was used 56V as pack full and 56.8V as alam voltage. Then also tried with 56V as pack full and alam voltage - in this case external meter will show around 95AH stored to battery.
Was anyone able to connect TDT 6022 BMS to esp32 via bluetooth and integrate the information on Home Assistant?
Anyone got accurate port descriptions for the TDT-6032? The on I have I am trying to use CAN to talk to the inverter. The BMS vendor (reseller) is saying use Port 4, however that appears to used for parallel battery communications and not to talk to the inverter. I saw another image that says Port 2 is for CAN communications to the inverter.
