So it wouldn't effect power going from the array? So I need one on each end of the pv wires?At the array, only protects the array.
At the SCC location can help protect your equipment.
I'm thinking one of these at the panels themselves :
One thing I'm curious about its listed as 300v dc but shows mcov of 470v. So its 470v max?
I would actually be putting one of these at each of the 4 different array sites I have.
Where it enters the workshop is 9 feet from the scc. Still do two or just one outside the workshop?The voltage at which it fires is well above the nominal PV (or AC system voltage.
I think that provides a path for earth voltage, elevated by lightning, to enter the PV wires.
Instead, put them where PV wires enter your equipment or the house.
I think better only at equipment end.
Or one where it enters your power shed, another at inputs to SCC.
I think none at remote PV array.
Well there is a reason I'm all over this method being discussed and it is ALL based on the insurance company I have.Any time we had wiring of any kind exiting or entering a building, we always put lightning protection at both ends.
Most of the time a lightning strike would take out the protection and still get our equipment.
We were able to improve our odds ..... but never gained total protection .... Your mileage may vary.Well there is a reason I'm all over this method being discussed and it is ALL based on the insurance company I have.
State Farm.
They are on a warpath cancelling peoples insurance that makes claims. Now the strike your referring to is mass damage. I would make a mass damage claim since it would cost a fortune out of my pocket.
Minor claims which this would be even if it was a bit worse isn't happening since they are the cheapest insurance around here to insure the house with.
So if I can spend some money and do some work to prevent this kind of minor effects in the future it makes perfect sense to at least try.
Any time we had wiring of any kind exiting or entering a building, we always put lightning protection at both ends. Most of the time a lightning strike would take out the protection and still get our equipment.
When we installed lightning protectors each one of them had their own ground rod that wasn't connected to anything except that lightning protector
That was per the spec of the lightning protectors we used .... They had to be able to shunt the spike directly to ground or they couldn't work.Yea that will kill your equipment.
Somebody misinterpreted the spec or used wrong type of protectors. Having multiple unbonded ground rods across your equipment is like the worst thing you can do in terms of avoiding ground potential surge pickup. You literally had differential earth current pickup rods wired across your equipment. No wonder lighting strikes blew up your stuff.That was per the spec of the lightning protectors we used
i’ve got one of those for each ground mount string (3 total)I would actually be putting one of these at each of the 4 different array sites I have
I guess all the engineers across 3 different companies I worked for misinterpreted the specs ..... These ground rods were in no way connected to our equipment .... the path to ground for the lightning protector was totally separate.Somebody misinterpreted the spec or used wrong type of protectors. Having multiple unbonded ground rods across your equipment is like the worst thing you can do in terms of avoiding ground potential surge pickup. You literally had differential earth current pickup rods wired across your equipment. No wonder lighting strikes blew up your stuff.
Oh the lightning "protector" is a type of lightning rod or air terminal? By lightning protector I thought you meant a surge protector that connected your electrical or data line entering the building to a ground rod.These ground rods were in no way connected to our equipment .... the path to ground for the lightning protector was totally separate.
They protect whatever is at the end that they are connected to.So it wouldn't effect power going from the array? So I need one on each end of the pv wires?
It had an active element that triggered at specified voltage level and shunted the voltage spike directly to ground thru a dedicated driven ground rod. It was a type of diode similar to a high current zener diode.Oh the lightning "protector" is a type of lightning rod or air terminal? By lightning protector I thought you meant a surge protector that connected your electrical or data line entering the building to a ground rod.
OK yep it was a voltage surge protector. My original comment stands. Connecting it to separate unbonded ground rod was very wrong way to do it.It had an active element that triggered at specified voltage level and shunted the voltage spike directly to ground thru a dedicated driven ground rod.
It was a type of diode with current only flowing in one direction .... to ground.And should also trigger to transfer elevated earth voltage to PV wires, allowing lightning current an easier path to reach your house.
