onrbikes
I've just installed a 24v x 200ah lifepo4 (self build) after years of lead acid. I've been offgrid for over 20 years and only use about 1kw per day. Not a typo, It's a well designed house.
I have plenty of solar charge.
A friend who is knows lifepo4 has balanced the batteries before installing, but isn't experienced with the victron set-up.
I've got a victron easysolar with a victron smart shunt and Daly bms. After 2 weeks usage, everything seems to be working fine but am fumbling around not really understanding what I'm looking at.
Lead acid always seemed to be doing something.
After reading many threads on this forum have set the system up to what I think is correct
I've attached a lot if screen shots and asking if these numbers look OK?
Any thoughts?
Thanks.
Any thoughts?
Thanks.
