I have a utility 24v I use to do various things like run the well. Right now it has a large lead acid bank with about 150amp of charge controllers (victron) hooked to it. I don't cycle the batteries, they are just there to cover for clouds that might be rolling through. I don't use it unless there is lots of sun.
The batteries are getting weak and I want to replace them with some cheap LFPs from Amazon. I would like to start with a single 24v 100a battery and add more as money comes in. My concern is the 150amps of SCCs hooked up. I can set them all to lower charge currrent but then when I need to run stuff when the sun is shinning my output is now lower.
My question is, does the typical BMS regulate the charge current to max or do I just need to get more batteries at the same time?
