Mix em all together and you will have a green system..about the color of your avatar critter.…HaaTo funny l have the "Blue" inverter ( Off "Blue" solar ) connected to the power supply that in turn connected to the ( "Yellow" DIY bank ) So I can connect them together. Day two of retirement. Kinda fun to "Play" at leisure.
Well would you look at that...... Sharp observation!Mix em all together and you will have a green system..about the color of your avatar critter.…Haa
I believe the CT option is only available for the multiplus 2s, not the original multiplus which the 500 and 1200VA are. Also the 500VA specs show it as not supporting power assist (only power control to limit input power demand).Do we know if these new smaller 500va and 1200va multiplus' can use a CT to grid tie inverter with limiting like their larger siblings supposedly can?
If you are pegging a 250/100 that will still peg a 450/100. I guess fundamentally if you are aiming for max winter production then there's a high likelihood that you'll be maxed out at times during the summer, or you have a bunch of SCCs to handle the summer max output but they'll be barely idling in the winter.So I went out and got a 250/100 to replace the 250/70. It still pegs at full output, but only for an hour or so.
Now I’m thinking I should have gone higher voltage from the beginning with the 450/100 or 200.
Good point, it really is the output current that is limited.If you are pegging a 250/100 that will still peg a 450/100
Do you have the right amount of panels to rewire in both the 250/100 and the 250/70?Good point, it really is the output current that is limited.
Now I need more batteries!
I really need to just let it go that the system will not always be running as efficiently as possible as the seasons change.
That’s a really good idea!Do you have the right amount of panels to rewire in both the 250/100 and the 250/70?
How much battery do you have?Good point, it really is the output current that is limited.
3x EG4-LL v1 = 15 kWhHow much battery do you have?
Done! Both the 250/100 and 250/70 are running. Thanks @G00SE !Do you have the right amount of panels to rewire in both the 250/100 and the 250/70?
Yeah, I feel like an idiot for not doing that sooner!Nice nearly 2.2kW additional harvest!
just wait until I finally get to updating my thread. You can return the favor and likely, quickly point out many idiosyncrasies I haveYeah, I feel like an idiot for not doing that sooner!
Now I really need more battery.
I like this forum for our idiosyncrasies, it's very entertaining!many idiosyncrasies I have
