First solar system install (other than RV setups) and I'm a bit confused on the MPPT specs for this inverter. The 6000XP has two MPPT's, each is rated at 17A and 480V max. Question is can each have a completely different voltage input or do both MPPT's need the same voltage input? Example one has 300V and the other say 250V. Manual isn't clear enough for this noob. I'm possibly dealing with an odd number of panels after some damage occurred this morning involving my skid steer. I'm good with buying replacement panels but if I don't need to id rather not.
