davesmith87
- Sep 19, 2021
- 24
Hello all,
I've got (2) MPP LV6548 inviters. These inverters can do 250v for solar input. Each inverter can do 8000 watts.
I currently have 24 panels (435 watts) in 2s3p setup. 4 combiner boxes. This put's me using about 10,000 watts (out of 16,000) in peak sun. I want to find a way to utilize the rest of the 6000 watts.
However, if I go 3s3p, this will put be slightly over the inverters rated max. My panels are 5 years old, and about 200 ft from my house (where inverters are). In the 3 years I've had them, I've only recorded 165v once (in 2s3p) configuration (this was in January when it was -10 out and sunny). Adding a third would put me just at about 250v or slightly over.
Could I simply add a breaker at 250v for each string right before the inverter? Any cons to this other than the breaker failing and not tripping?
Ideally, I would just get a higher capacity charge controller, but don't want to replace my inverters.
Thanks in advance,
Dave
Thanks in advance,
Dave
