Why Do I Need an Inverter/Charger if I have Solar?
pdaddy
Denver
So I'm building an 800w solar panel system for my travel trailer. It already has an inverter (only 1000w so will probably upgrade to 2000w so the wife can run a few more things like her hair dryer, LOL". I have a 200ah LifePo4 battery.
I'm reading about inverter/chargers combos. But if I am connecting my MPPT controller directly to the battery, what would be the reason to ever purchase an inverter/charger combo unit? Seems like the inverter is all I need since the solar charges my batteries directly. Am I thinking about this the right way?
Will there always be enough sun? If yes, no charger needed. If a few trips prove you wrong, change the converter to a lithium converter and power the generator to charge.
I use a ac to dc converter for back up charging. Once a year i test it. Other than that, I don’t use it.
Thanks. Should have mentioned I do carry a 2000w gas portable generator as a back-up in case the sun disappears for a few days.
the inverter charger types are handy if your solar does not make enough power to charge your batteries other than that there is no advantage. you could use a normal battery charger in lieu of an inverter charger if your system is 12 volts.
an honestly if you have 800 watts of solar that goes a long way in a camper unless you are running your a/c or furnace off of it. Add another 200 amp hour battery and you should be able to go several days without solar at all.
The inverter-charger I chose, a 3000/9000-watt unit, can charge at up to 90 amps while the onboard converter is rated at an unrealistic 55 amps.
Our camper is equipped with four 190-watt panels on the roof connected to a 60-amp mppt controller. That setup does an admirable job of recharging our 800 ah lifepo4 bank, even in cloudy conditions.
The inverter-charger gives us the ability to charge batteries with two paralleled 2300-watt inverter-generators if;
We need to run the rooftop air during night time hours (like during the Oshkosh Air Show)
If we have several days of rain/clouds.
Thanks. I think my 800 watts going to the 200ah battery is plenty of power to recharge pretty quickly... especially when I'm using 90-100 Ah per day.
The RV converter you have already may or may not charge your battery for those days. If its a constant voltage 13.6 like most RVs seem to be, will be fine. If the RV converter is a three stage, needs to be off at all times. The max charge voltage is around 14.6 volts for Lithium.
Just leave the RV converter off when not needed.
Reactions: FLD
