SolarScott
- Sep 27, 2022
- 476
Put one 15 foot from back end of barn about 7 foot high.....want to be able to direct turbo air right on me if I am working on something....put the other about 15 foot inside from the door, same height. I believe the air stratifies and keeps more of the cold air where I want it, down low. This think only has an inch of spray foam and my homemade doors leak like hell......hope to get some brush seals around the doors sometime soon. But buy gosh, it sure works better than I had hopped . I like single head, redundant if one fails.Where did you mount the inside unit? I've been debating high on the wall or down low for easier cleaning of the evaporator coil. 18 foot ceiling.
I'm planning on two 24K units. I'm not certain if I want dual head either. I will still have the older lower SEER rated 2 ton unit with air handler for backup or additional quick cooling if needed.
