Helping my father design a solar system for an off grid cabin. The biggest hurdle is the cost and size of a system to run a freaking 2hp well pump. Doing a bit of research these are the options I think, which is best?
1. Generator at pump house to storage tank in garage.
2. Big system to accommodate 2hp (4,000 running watts) 8-12k start up.
3. Generator auto start up to feed pressure tank?
The well is a couple hundred feet from the cabin so added cost to run wire down there for options 2 and 3. Good south facing slope for solar panels, in the pnw. Running propane for fridge, hot water heater etc. wood stove for heat. So Cabin wouldn’t need a big system without the well.
