Rabbit
- Nov 19, 2019
- 85
I currently run a small (1220 watt) home solar plant with golf-cart type lead acid batteries as my power-bank. When I bought these batteries-- there are eight of them, and from time to time I've wished for a bit more capacity-- I learned that I had to buy all the batteries at pretty much the same time, so that the older and therefore weaker batteries wouldn't limit the total capacity of the bank. I'm now considering buying two high-quality 12-volt 100AH batteries for another non-related low-use purpose, but may want to include them as part of a replacement LiFePO4 bank later, when my lead-acid bank inevitably dies and needs to be replaced. So... With high-quality LiFePO4's, can I buy two now, use them (lightly and gently), and then add two or three more of the same brand/model/etc to make up a larger bank in probably about two or three years without significant age- or use-cycle related issues? Or do I need to buy all four (or maybe five) now, all at once, and just let two (or three) pretty much sit around doing little or nothing in the meantime? Or, perhaps worst of all, should I just grit my teeth and rip out a perfectly-functional, paid-for, and satisfactory lead-acid bank, sell it for what I can, and go LiFePO4 today? (If I do this, I'll have to dis-assemble the new bank several times a year to pull two of the batteries for the special, non-solar purpose I mentioned earlier. A pain in the ass, yes. But not an impossibly huge one.)
What would you folks do? I'm going to require those two LiFePO4's for the non-solar purpose fairly soon now, so this isn't merely a theoretical question.
