Sundog33
Sun Bather
So, I finally jumped onto the Lithium band wagon after finding Will on Utube. As he stares many times unlike Lead acid batteries that can only use 50% of their capacity... Lithium Batteries can use 100% of their capacity.
In reality Lithium batteries cannot go below 20% or they will be damaged and should not be charged above 90%. My Overkill BMS default settings actually cut off charge at 87%. So that leaves usable capacity of Lithium batteries at 67%. Hell of allot closer to 50% than to 100%.
Secondly, a big selling point is slow discharge rate. I could never monitor what my 2 105ah AGM batteries were losing but my BMS shows I lose over 10% capacity overnight with LIFePO4 with no draw except a unmeasurable milliamp volt display attached.
Dont get me wrong. The ability to monitor my system on the iPad is way cool. But if someone was to tell me; you can spend $700 on a 200ah Lithium Battery, Overkill BMS, etc... and end up with about the same capacity as my existing setup.
Or you could use that money to buy 2 more 100watt panels and 2 more 105ah Batteries and double my capacity. I may have thought twice.
in the end I would most likely have did it again as my AGM batteries were 10 years old. (Still showing 96% and 76% respectively ).
but just let’s not give people unrealistic expectations.
