joegambler0
- Jan 5, 2020
- 23
Hi Everyone, Thanks a bunch to William Prowse, I'll buy as much thru your Amz links as possible to support u. I need an off grid system for my TT. I will use 10-100W rigid panels, a 3000W inv, 1-80A or 2-40A CC and AGM Batts. As far as Batts, I can do as far as space, weight and $:
4-6V 220AH in ser/par=440AH 12V or 2-6V 400AH ser=400AH 12V or
2-12V 210AH par=420AH 12V
Now if I did a 24V:
4-12V 105AH ser/par=210AH 24V or
2-12V 210AH see=210AH 24V.
I understand all the benefits of a 24V system and would like to use it, but isn't it cutting my amp hours in half compared to a 12V system? Or since it's 24V and it goes thru the inverter more efficiently to 120V and it has to step down also to 12V, does it change the AH? Or is amp hours amp hours no matter the voltage? Please help unconfused me and please don't try to convince me to use lithium. For right now I can afford the AGM. Thanks.
Now if I did a 24V:
