EndlessSun
- Jun 23, 2021
- 5
Hi guys, Im so happy I found this place.. I have been watching a ton of YouTube videos and reading but I had some specific question. I wish I could talk to someone and see if what I want makes sense. this seems to be the closest thing to it.
We use our 27ft Cruiser for a weekend at a time, have been planning a few 2-3 day trips.
I want to be able to use the AC(4-6hrs at the most per day), microwave, TV and some outlets to charge phone/computer while on the water. (not necessarily all at the same time)
So since I started researching I figured I could somewhere around 400-500ah battery.
AC is a 8000btu 115v/60htz Max Cool 5.4amp Max Heat 7.0amp
My space is limited, I have some room in the aft cabin. I would like to build the batteries vs buying to hopefully fit in that space.
Charging:
Boat stays in the water, and I have access to 110v and usually have it plugged and have my battery charger running. So I was thinking I could do the same with the LifePo4 since I will be back to the dock daily. and I want in the future to add a few solar panels for those 2-3 day trips.
is it possible to tap into the Main Shore Power from the Inverter/lifePo4 since everything I want to run is already in the 110v panel?
Im looking for a simple set up that I can later modify to be able to charge from alternators and solar, also possibly to increase battery ah capacity.
looking for recommendations on:
- Cells
- Inverter
- BMS
- Charger
- etc
Sorry for the long post.
thanks in advance for all the advice and thoughts.
Dan.
Charging:
- Cells
- Inverter
- BMS
- Charger
- etc
Dan.
