I have BMW Batteries that use the NMC cells.
I'm on the fence about Min / Max voltage settings
I'm using these batteries in a 14s setup for a 48v system
I found out my Solar charge controller isn't as user friendly as i thought. ( Epever AN6415 )
I know i'll need to use the USER settings.. and i have the MT50 controller to do the settings.
But some parameters are confusing for me to set. ( i think i can figure it out eventually )
Anyway i'd like to know if i am safe to use 4.1vpc max, and 2.9vpc min. ( vpc - volts per cell ) or should i raise or lower
And should these be top balanced or bottom balanced ? ( i don't know what the difference would be )
the spec sheet says 4.15vpc max and 2.9vpc min.
Like everyone else, i wanna make sure i get the most out of these batteries.
any advice is appreciated.
