Being new to the forum I am not sure where is the best place to ask this.
I am in the UK and currently have a standard 4KW system with 12 Sunpower Panels and a Fronius IG inverter which feeds to the single phase grid on a FIT agreement so this system cannot be changed and will not function in an off-grid setup.
I want to add another 5KW system with a separate Hybrid inverter and battery pack, firstly to balance the usage through the day and secondly so that I can have whole house backup in case of a grid failure with this new PV array also able to charge the batteries and provide house power when there is no grid.
I suspect that I may also have to have approved export limiting but this needs to be confirmed with the DNO.
I have identified a way of doing this with a Fronius Primo Gen24 Plus 5KW with BYD HVS 7.7KW battery, 14 x JA Solar 370W panels, Fronius Smart Meter and some form of grid protection although I am not entirely sure of the setup of this.
One disadvantage of this system seems to be that even with an ATS there is a delay of 60 seconds before the inverter kicks in if the grid fails, but is this a regulatory thing.
Also the potential cost of the grid protection as the only solutions that I have seen are the TeleHaase NA003-M64 and one from Enwitec which may do the job but do not seem to be widely available and I suspect are expensive and probably overkill. This makes me wonder if a manual switchover or simple contactor solution is a more economical way of doing this but I am not sure how this is cabled to work in both off-grid and grid tied modes.
I am keen to hear advice from any forum members who have experience of this type of setup or any other ways of doing this as I am struggling to get any installers to give constructive information, partticularly with UK regs.
