A handful of people around here recommend low frequency inverters, I wasn't aware of the distinction before joining this forum, and most companies don't seem to push this as a marketing point and most reviews don't mention it. And I've found very few clearly marked low frequency inverters at the small (<2-3kw) end of the spectrum.
I'm wondering, are LF inverters one of those things where the saying "If you don't know if you need one, you probably don't need one" applies?
Can someone ELI5 (explain it like I'm 5 years old), the benefits of LF inverters / drawbacks of HF inverters?
What I have gathered so far:
Pros of LF inverters:
How about efficiency and power consumption at idle, any differences?
If these are the main differences, it seems that priorities would have a lot to do with how much sense it makes to go LF. If you are building an off grid home and designing a system to last 20+ years, where size and weight aren't a big issue and the cost of a LF inverter relative to your overall budget is somewhat small, and your AC demands are higher, LF probably makes a lot more sense. If on the other hand you are building a small mobile system where size and weight matter and where the cost of the inverter will be a big chunk of your budget, LF might make less sense.
- Longevity / reliability
- Higher peak/surge power rating (~200% for HF >300% for LF)
- Cost
- Size/Weight
