Van Life - Sleeping Above / Near Batteries Inverter etc
Rocksnsalt
SoCal
Hello, this may sound kooky / cra cra to some… but intuitively it just seems like a bad idea to sleep directly above or near a LifeP04 battery bank and inverter etc.
Many vans and rvs are built with the electrical system in the “garage area” directly below the bed, along either side wall of the van. My garage will also have mountain bikes in it, and I want to be able to access it from the frontal “living space” area, so installing the system laterally across the van is not an option.
A Small system like 100-200ah would probably be a minimal health risk but larger system like 400ah or 5kw or 10kw+ seems like the chances of a negative health consequence would increase.
One solution is to mount the batteries under the vehicle, which also saves precious space in the van, but it’s more expense, fabrication, work, and not ideal in cold weather camping.
Any health consequences would likely not show up immediately but possibly months or more likely years later.
Any MD’s or other medical professionals out there with thoughts on this?
I didn't see you mention what battery chemistry?
Lead acid batteries tend to put out hydrogen gas (unless they're sealed)...
I wouldn't think LiFePO4 would be any problem, they don't even have risk for thermo-runaway or anything related to fire or meltdown, I would think they are fine to put anywhere convenient.
If I had one of the lithium - cobalt chemistries, I might be a little more concerned about having a fire escape strategy though.
DOH! My error for omitting. ??‍♂️
LifeP04.
I added that to my post thanks
Well I couldn't speak as an MD (unless you consider Mechanical Donovan as some type of credential)...
LiFePo4 is safe enough for RV use, we have been running a 240ah pack under our bed for 3 years, it is fused on the stud and is enclosed with ventilation ports to reduce heat.
I'm am upgrading our system to 608ah as soon as the new cells arrive and have not issues with using the previous pack off-road
As far as i know there aren't any health issues, i dear say that our phones cause more issues than a battery pack.
but i'm not a doctor, nor does it concern me, i'm more likey to be killed by a road accident
Like I said, health issues wouldn’t necessarily occur soon, it would likely be years later after repeated exposure near the brain. And I agree re cell/smart phones.
admin: please feel free to close this thread, I don’t see a way for me to do it.
Yeah, thats what farmers said about roundup 40 years ago…
different since it’s an actual airborne chemical yes, but just sayin’
The controversy over cell phones and health risk had more to do with microwave RFs in close proximity to the body (mainly implied on the tx I assume).
Some might argue that low voltage EM energy could actually help health...
Many more articles, my Mother swears by this type of therapy, and says it can help heal the body. Companies actually make devices like belts and pads and stuff that can be fastened to the body which are supposed to help certain health issues.
I am not pro or anti on any of this topic, but just putting it out there for consideration.
I would think that as long as the battery bank isn't emitting any kind of harmful gases, or leeching chemicals from the materials they are made out of into the air, then any effects related to EM energy coming off of them would at least be harmless (speaking of the battery bank circuit voltage, not necessarily inverters or any other device in a system which could generate high-frequency noise into the localized airspace)...
We have had batteries a long time, and many other chemicals that are no longer permitted to be used in the USA.
but back to batteries….
Until very recent years there was not a whole sub segment of the population in some cases sleeping with their brain and other organs a foot or 2 away from a massive LifeP04 battery bank, inverter etc.
But anyway no need to respond anymore I’ve asked admin to delete this thread.
Why? It is actually a valid discussion. I'm sitting 5" above 5.2kWh of LiFePO₄ batteries and a solar charge controller, and my back is 6" from my 2kW inverter (though it's not on at the moment) as I type this.
Hehe, that means I'm living in EM paradise. With everything I have humming running around me, I might even glow in the dark. :eek:
Caution when it comes to health and environmental impacts is reasonable and prudent. As you have alluded to, there is sometimes a long lag of years or decades before we come to understand the implications of some new thing. At the same time its probably not productive to let vague/undefined fears dominate your thinking, without trying to untangle and develop what is and what is not realistic/possible, and what vectors for harm may or may not exist.
With LiFePO4 for example you are talking about 'actual airborne chemicals' but my understanding (as a layman) is that unless something goes very wrong (which would require multiple simultaneous failures in a well designed system), there is no venting with LiFePO4 batteries. There should be no 'actual airborne chemicals.'
That said, there is absolutely nothing wrong with erring on the side of caution, its a smart approach given limited information, if there is one thing we do in abundance on this forum, its overbuild+overthink. If you are worried about the potential for venting, you could build a battery enclosure that vents to the outside or is sealed in some way, and/or make sure there is adequate air exchange/ventilation in the living space (this is a good idea regardless).
The TL;DR is try to define the specific risks/worries then assess each of those individually rather than focusing on an amorphous idea of possible harm.
@Dzl Well said, and good job covering both sides of the argument, you'd make a good politician, chuckle, teasing, okay, I find humor, after the light of day, to be the best antiseptic.
That being said, I've survived the game of life for 69 going on 70 years now. Heck, we used to hunt dinosaurs for food back in the days, and I can comfortably say that batteries and inverters are the least of your worries. I'm much more concerned about what's in our food, air, and water; as for EM, at the speed of light, we're 8-minutes away from our sun. Momma used to say, "what don't kill ya makes ya stronger." :cool:
Some valid points and acknowledgments.
Re airborne chemicals I was talking about roundup.
I wouldn’t be concerned about ingesting chemicals from LifeP04 batteries or an inverter unless there was a meltdown or fire.
My point is more about longterm exposure from sleeping with ones brain and vital organs in close proximity to relatively high power electrical storage and devices.
We don’t really know if there’s any effect since there likely hasn’t been any studies specific to this.
Don't get me wrong… I’m not stressing on this question at all, just something that popped into my add brain recently so I thought I’d throw it out here, which in hindsight was not the best type of platform for this question.
That said…
Admin, PLEASE delete this thread.
Thanks
My mistake, I totally misread/misinterpreted that comment.
One possible strategy you could take if you want to be cautious (which has other benefits as well), is turning off the inverter, or better yet, only turning the inverter on when you need it. This is somewhat common as a power saving measure already.
Actually I think its a pretty valid question/topic for a forum like this. Since as you mention, many more people today are sleeping in close proximity to their electrical systems, I imagine you are not the only one who has pondered the health and safety considerations. As to deleting the thread, we don't normally do that with established/active conversations without a clear reason if there is interest in the topic. If you would like to no longer participate there is a little 'unwatch' button in the top right, or feel free to PM me or another moderator privately (or report the post with the reason for deletion stated in your report) if you think there is good reason to delete the whole thread.
Right….
Yes thought of shutoff etc but ideally looking at being able to possibly power ac or heat at night.
thanks I guess just let the thread ride and we’ll see what dipstickery comes of it, and hopefully some good info as well.
btw here’s a pic of the VOLTA 12kw system that is used in the Storyteller Mode Vans.
it’s on the right in both pics, bare, and enclosed.
The battery system is stored on the passenger side over the wheel well.
In their layout either the occupants feet or head are directly above the 48v 12kw battery bank etc. when sleeping.
For most, that will depend on how level the parking area is.
I’d love to have one of those vans but just a bit pricey…
So I’d love to be able to diy a similar - but simpler system someday in my sprinter, using EG4 batteries or similar.
Theirs has elaborate controls, 11” led screen etc.
