Rbertalotto
- Nov 26, 2019
- 395
Wow, haven't seen the word "litz" since my audio engineering days......Was a bi#@$ to solder!
Really? My code instructor said the oxidation layer formed when the strands are made increases the amperage ability from skin effect on KV conductors. They even have compressed strands on the big stuff for feeding skyscrapers with KV service...There's not skin effect with DC, only with AC, and it only matters if the frequency is higher than dozens of kHz (or a bit lower than that if we're talking about very large currents and very large wire, but that's not often you see that).
Also, even if there was the skin effect with DC you need isolated strands (it's called Litz wire) to have an impact, if they aren't then it's equivalent to a solid core conductor in regards to the skin effect.
... I actually have a 10ft chunk of that in the front seat of my truck...He could just go parallel 750kcmil and sleep well at night
Or were you saying the skin effect on isolated strands was for dc?
Yup, tinned is critical in marine use... just not so much otherwise.I do lots of work on boats. Countless times I've cut a piece of wire well away from the ends and there is corrosion on the copper. Only thing that stops this is tinned wire.
Somehow the corrosion gremlins are getting through the insulation feet from the ends pof the wire.
Tinned, heat shrink with glue and closed toe lugs.... totally sealed up.... and it can still get in.Yup, tinned is critical in marine use... just not so much otherwise.
I would have thought that a simple 'silver' washer between the post terminal and the cable or bar connection would eliminate all galvanic corrosion. If the heat shrink is applied right up over the lug shoulder, how does the atmospheric 'salt' get into the cables(im assuming the cables never get wet), plus, would these pouches that absorb all moisture in packaging etc(forget what they're called), if added to a well sealed battery containment area, could that not prevent corrosion over a long period. (I have no experience of marine instals, just wondering about possibilities)
We have both Ancor marine-grade 4/0 and Cobra X-Flex 4/0 welding cable (though I don't think we list the welding cable, it's more for us to play with) and I can confirm that the welding cable is significantly more flexible than the Ancor.Is there anyone here that has experience using 4/0 awg ancor marine grade wire that can vouch for its flexibility compared to welding cable?
I may just go to a welding supply store and then to west marine to compare the two before making a decision.
It's good to hear from some real world experience like this.I do lots of work on boats. Countless times I've cut a piece of wire well away from the ends and there is corrosion on the copper. Only thing that stops this is tinned wire.
Somehow the corrosion gremlins are getting through the insulation feet from the ends of the wire.
If you run it inside a braided cable jacket, well routed and secured on a car/truck. How much will the minor grease/oil effect EPDM?We have both Ancor marine-grade 4/0 and Cobra X-Flex 4/0 welding cable (though I don't think we list the welding cable, it's more for us to play with) and I can confirm that the welding cable is significantly more flexible than the Ancor.
That being said, the flexibility has nothing to do with strand count - the Cobra 4/0 welding cable has 2,107 strands of 30AWG pure copper, and the Ancor 4/0 marine-grade cable has 2,109 strands of 30AWG tinned copper. The increased flexibility of the welding cable is purely a matter of the jacket material. Welding cable jacket material is EPDM which is soft and flexible but not very abrasion-, chemical-, or UV-resistant. The Ancor cable is less flexible because the jacket is PVC for the requisite resistance to abrasion, chemicals, and UV exposure.
You'll be fine running it that way; on a number of our RV and other mobile customers who aren't in coastal areas we'll regularly spec welding cable for ease of use.If you run it inside a braided cable jacket, well routed and secured on a car/truck. How much will the minor grease/oil effect EPDM?
I was going to ask TEMCo, but you're here on the forums.
