Ok, getting closer to completing our Grid Tie project. Our Array consists of 33 - 400w panels wired in series. Originally, the plan was for 3 - 11 panel arrays but due to a change in plan (another Inverter selected), we needed 4 arrays. NOTE: the Inverter has 4 DC + & - inputs
So, we have 3 - 8 panel arrays and 1 - 9 panel array.
The voltage output for Arrays #1, #2 and #3 are fine. The voltage for the 9 panel Array #4 is only about 38% of the output of #1, #2, and #3.
You'll see on the attached wiring diagram, I've wired the 9 panels in series with both the + pv wiring and the - pv wiring terminated at a 3-way splitter.
Again, the voltage for Array #4 is about 38% of the output vs. the other Arrays. When I test the voltage at the 3-way splitter for zones "A" , "B" & "C", each come up with the same output....which is also identical to the output off all circuits hooked up to the 3-way splitters.
Am I just having a brainfart....overlooking the obvious? Why is the voltage output for Array #4 much less vs. the other Arrays? Is the wiring incorrect? Are the 3-way splitters the issue?
Looking fwd to your responses! THNX!!!
