I have a small toy hauler that I am adding a 400w solar/300ah 12v lifepo4 system to. My tow vehicle came from the factory with a 150 amp alternator, dual batteries and a 1000w inverter. The truck was setup up from the factory to provide charging power to either a camper or tow vehicle. I know the system is designed for lead batteries is there a way to convert it to be safe with lifepo4. Would it be better to disconnect the trucks charging system from the trailer? Also the lifepo battery I am using has a charge limit of 100 amps.
