I am modeling my battery after the 8S 24V block setup except I will have two 8S blocks in two steel boxes with two 8S 24V 100A OverKill BMS's. I'm hoping to create a 8S2P configuration. I'm not sure how to wire the two boxes together. If you wire up two 8S packs, each with their own BMS how do you run them in parallel?
