Radiant Vs Convection heat
Key differences of radiant vs convection heat explained. How they have totally different heat transfer characteristics and energy implications.
www.herschel-infrared.co.uk
More efficient use of the available heat. Radiated infrared warms better than air heated by convection in a room. Same reason a wood stove feels so much warmer than a pellet stove.The heat is still in the room though? So it is not making more heat?
Same BTU's but the infrared in the ceramic doesn't "see" the air although it will radiate to other solids like your body. Or so I've heard on the internet.The heat is still in the room though? So it is not making more heat?
Oh. Of course, I can do it… just not elegantly… and reversing the setup would involve reconnecting 1/0 lines in fridgid weather without a means of disconnect…
I will replace the entire electrical panel with a better panel that I can install an interlock on… and add a 50A generator inlet.
We don't have "consumer units" , we have service panels. And they are not required to have a main breaker in certain circumstances. The only way to kill a main lug panel is to pull the meter.Don't your consumer units have dual pole isolation ? We have to have it over here by law
Isn't that the country that believes it's citizens can defend themselves from Polar Bears with rocks, sticks, and proper pronouns?...ohh that sounds safe lol . have you tried moving to a civilized country? Possibly Canada
In a condo, there is a main breaker panel somewhere under the control of Maintenance, and each condo or apartment is just a sub-feed with a small breaker panel, and no main....ohh that sounds safe lol . have you tried moving to a civilized country? Possibly Canada
Its a condo, you don't, the maintenence team probably does.how do you work on your electrics if you can't turn them off ?
There are breakers for individual circuits, but no main breaker for the whole panel. But like Lt.Dan said, working on that stuff in a condo/apartment is usually frowned upon.how do you work on your electrics if you can't turn them off ?
No way. lol...ohh that sounds safe lol . have you tried moving to a civilized country? Possibly Canada
No way. lol
It's 17F now.
It's a freakin heat wave. lol
