Madco
system is: two inverters configured split phase, each with 3.4kW of panels connected to PV1.
The 2P1 inverter loses about an hour per day on its clock, the 2P2 inverter does not.
The 2P1 inverter's MPPT input "idles" around 285W until I interrupt the input, then it instantly increases to match generation of the 2P2 inverter's MPPT input, around 2kW in this example. The 2P2 inverter has adjusted the panel voltage to around 315V while the 2P1 inverter is running at 90V until I interrupt the input, then it adjusts to a similar voltage, around 320V.
Anybody experiencing similar behavior?
