any old 19" server rack will do..Hi,
I'm trying to rack up 3 eg4 batteries. Ideally rack would be castered for mobility. Any suggestions that are more affordable than the EG4 branded rack at $450?
Thanks.
Are standard server racks going to be up to the weight of these batteries?What houseofancients said. A data center that is selling off old equipment is what I would look for. However, be sure you know what size rack your batteries needs. Not all server racks are the same.
half size definitely ( should be enough for 6), if in doubt add a metal bottom plate to be welded inAre standard server racks going to be up to the weight of these batteries?
same here, although mine a labeled 3par ( their san storage division)I have an old HP server rack in my garage. I suspect I could easily put 500 lbs in it.
These server racks have been used to mount UPS batteries in server rooms for decades. It’s only recently these racks have been used in the solar industry. Not sure why it took so long for the manufacturer to go this route because it seems like such an easy starting place. They seem late to the party really.Are standard server racks going to be up to the weight of these batteries?
Agree. I’ve seen pics here where someone heatshrink-wrapped the bus bars but personally I’d just take them out. They’re an invitation to sparks flying.The EG4 rack is junk simply because the busbar design is horrible and ruins an otherwise great rack. Any 19” rack mount server rack with a door will do in my opinion.
