Just want to share an observation.
I have a 600w microinverter connected to 24v system which is supervised by JK BMS 40A.
I used to use a resistor to pre charge the inverter but lately found that if I disable "discharge" in BMS and connect the Inverter, there is no need to pre charge it separately.
The inverter power light comes up after couple of seconds indicating that the capacitors are charged.
Only then I turn the "discharge" of the BMS.
Would like to understand of there is anything I should worry about in the long run.
