Now I need to figure out if I can fit everything on a wall, including clearances, etc, ceiling height is ~8 feet usable (after accounting for ceiling drywall and flooring.
From top to bottom including clearances
- 6 inch top clearance
- 32 inch sol ark
- 6 inch bottom clearance
- wireway
- 10 inch for homegrid stack'd
- 6 inch (tight), 8 inch (remove wheels) eg4 ll rack
- battery
- 41 inch battery size for homegrid
- 46 inch battery for eg4 ll rack
I wonder if I could try for a 6 inch by 12 inch wireway, but it doesn't look like anyone sells those (and it'd need to be nema rated).
I'd have 104 usable inches if I didn't have to deal with the sewer pipe.
![PXL_20230809_185100242.jpg PXL_20230809_185100242.jpg](https://diysolarforum.com/data/attachments/175/175444-5b52595ed0fb21792e9cdcf8746c162d.jpg)
18 inches out from the wall, once a wall is installed with insulation behind it that'll be ~12 inches if I use 1 inch of insulation instead of 2 for that area.
9 inches from the ceiling, so in order to use that area behind the pipe I'd have to slot the sol ark up into it to mount (12 inch depth and cover some of the front) not worth it and probably actively bad.
Am I over thinking things?
Should I just use the eg4 rack on castors and have it in front of the wireway (disconnect and roll it away if I need to open things up)? It'd be installed after initial solar install. I suppose it feels like it's so close to fitting but won't in that area.
