LOL, you guys are swimming in power. My 10kW array generated about 100Wh today!
At least for my neck of the woods, this coming week looks very promising, 2-4 days are forecast to be clear with the rest mostly clear and no snow.This is such a sad thread.
But it helps knowing that you are not alone.
Forecast here was sunny all day. It wasn't, dark and overcast. So don't count on the weather person.At least for my neck of the woods, this coming week looks very promising, 2-4 days are forecast to be clear with the rest mostly clear and no snow.
Went on a 3 hour trip to buy something, came back and Batrium had shut down everything. Checked logs, couldn't find anything, battery was still at 53V. Tripped about an hour after I left, battery was at 38% when I left and still at 38% when I fired everything back up.
My phone went bonkers today too while traveling, just weird stuff all around. Solar flare today?
Was suppose to be full sun here today also in central wi. It was cloudy all day and it snowed over night so I had to clean the panels early, they are ice covered as the snow was wet and then got colder and froze. With 57kw of pv, I only made 16kwh. all day.Forecast here was sunny all day. It wasn't, dark and overcast. So don't count on the weather person.
Dang you have twice as many panels as I do. I thought 30 kW was big.Was suppose to be full sun here today also in central wi. It was cloudy all day and it snowed over night so I had to clean the panels early, they are ice covered as the snow was wet and then got colder and froze. With 57kw of pv, I only made 16kwh. all day.
I'm counting the seconds!Look on the bright side (pun not intended)...
We can all(*) start celebrating after Fri, 22 Dec 2023 @ 3:27 am UTC
* By all, I mean all on this thread - apologies to our southern hemisphere members!
Do it.Thats it, I need to build some kind of steam generation system for when the zombie apocalypse hits and you cannot get fuel anymore except for wood.
No sun for 2 days here, 1 day of sun in 2 weeks aint cutting it.
Forcast shows 4 days of sun comingup finally.
We drove over to Black River Falls to get a log splitter, roads good until the last 25 miles. Pure ice. At home it snowed but roads were dry. Any fixed ground mount here was still covered with snow but my 65 degree tilted array was perfectly clean.Was suppose to be full sun here today also in central wi. It was cloudy all day and it snowed over night so I had to clean the panels early, they are ice covered as the snow was wet and then got colder and froze. With 57kw of pv, I only made 16kwh. all day.
