Hey guys. Well I made a dumb mistake leaving the front panel of my MPP Solar Inverter open. I mouse got in and squeezed into the main compartment. He did some serious damage to my data cables. (See photos) I'm in the process of trying to get a new set of cables direct from the manufacturer, although the correspondence has stopped.
Does anyone know where I can buy these ribbon cables with appropriate connectors? I chatted with Ian at Watts247 and he mentioned to search for IDH header, but I can't seem to find anything relevant.
I'd appreciate any direction on this. Thanks and don't make the mistake I did. Always seal up your equipment!
This is what I sent to MPP Solar Support for cable replacements needed: (Total of 6 cables chewed)
- (CN1) 8 Pin cable from (CAN POWER) to main board (HFPW) (CN6)
- (CN1) 2 pin AC start cable from main board (HFPW) to (COMM)
- (CN6) 6 pin cable from vertical circuit board to (COMM)
- (CN5) 3 pin (2 wire cable) from MPPT to SPS (CN3)
- (CN14) 2 pin cable from (HFPW) to another connector on main board (HFPW) under a large aluminum heat sink
- (CN12?) 2 pin cable that runs from HFPW to a connector under large aluminum heat sink on main board (HFPW)
