Nesto514Rides
- Sep 19, 2022
- 13
Hello, I am going to double my battery capacity. Currently I have a LiTime 200ah 12V 100A BMS battery. I am buying the same battery to add to my system. My question is with cabling. With my current set up the cables that go from my battery to my system are set up to handle 100a continuous, although I have never pulled that many amps and my typical usage is 20 amps. I understand that by adding a second battery the amp draw will be split between each battery. So my question is the jumper cables, do I set them up for 100 amps and then increase the size of my supply cables to handle 200 amps? TIA.
