farmhand
- Aug 26, 2022
- 232
Hello all!
I have two arrays now mounted (one fixed, one tracking). One array has 12 12v 100w HQST mono panels, the other 12 12v 100w HQST poly panels.
I am confused on CHARGE CONTROLLER PV VOLTAGE: Example; 12v panels put out 18-20volts... SO; Is a 48volt PV input made of 4 12v panels in series, producing nearly 80v? Or is a 48v system made of 2 12v panels in series, producing nearly 40v?
ALSO: Attached are the spec stickers from the back of the panels, CAN I put 12 of these panels in series, and what would the "charge/PV" voltage to the input of the charge controller need be rated for?
I have NOT yet ordered any controller or inverter, trying to save of copper. Both arrays are 30' from the controller/battery/inverter locations.
Thanks!
Thanks!
