I had thought if I ran 3 pair of 100 watt panels each set in parallel and then connect the sets in series I could get 600 watts through a 30 amp 50 volt MPPT controller. Thoughts?
I am running a 12volt system. I am running the panels flat not tilted so I will not be getting the full output from the panels which is why I am going to 600 watts. Thnx for the help!
Yeah i don't see any issues .. are you running LFP or other?? Just curious ... And YES - running a FLAT mounted cell you are going to probably be pushing only getting 60% of the max anyway ...
