JasonHaws
I want to put in a 48Volt Battery Bank System in my RV. More Specifically a 48V Trophy 304AH battery so all I need is 1 battery to hook to the Inverter.
However, with a 50 amp service I don't see many options for both legs to go into an Inverter. Even the 48 volt Victron MultiPlus II only shows one hot line in.
My thought was to get an EG4 6K 120/240 split phase inverter so that I can put the two legs into it and have two legs coming out to power both sides of the RV's electrical panel. Is there a better way to do it? the EG4 6500ex seems like a lighter simpler option but I only see a spot for 1 leg in.
To power the 12 volt side of the RV I figured i'd need a DC to DC converter to step it down from 48V to 12V.
