I found a similar post about this, but it doesn't quite answer my question. I'm in Texas, but I've read that California requires the AC disconnect to be located near the inverter. But I've also read that it is best to have the disconnect outside for easier access to first responders, etc. Since my inverter will be inside the garage, which is the best location for the disconnect, inside or outside? Note that the inverter is only a foot away from a door going outside and the disconnect would be maybe 4 feet away from that same door if it is mounted outside. In other words on opposite sides of the same wall with a door a few feet away.
