Specification
Nominal input voltage: 12.8~13.2 VDC
Operating input voltage: 10-15 VDC
Nominal output voltage: 115 +/-10V AC
Continuous output power: Up to 3000W
Surge output power (0.1 second): 6000W
Input overvoltage shutdown: 16±0.5VDC
Input undervoltage alarm: 10.5±0.5VDC
Input low voltage shutdown: 10±0.5VDC
Operating ambient tempreture range:32-104 F
Output wave: Modified sine wave
Internal fuse: 40Ax8
USB port:DC 5V/2A
Weight:11.094 Ib
Packing List
1 x Potek 3000W Power Inverter
4 x Car Battery Cables
1 X Earth Wire
1 x User manual
Notes:
● Potek also has the
Red 3000 watt power inverter on sale now. Check it out.
● Warranty: 18-month
● please use the battery clamp cable with a connection directly to the 12V battery while you run any loads higher 150W but lower than 500W.
● Do not use high power electric devices such as hair dryers, electric heaters, curling irons, vacuum connect the inverter to a battery.
● Please do not leave the power inverter in the ON position while your car is off.
● Disconnect the positive battery terminal before doing any wiring to the inverter.
● Keep the unit away from water and flammable material or in any location which may accumulate flammable fumes or gases.
● To reduce the risk of electric shock, unplug the unit from the outlet before attempting any maintenance or cleaning. Turning off controls will not reduce this risk.
The inverter draws low amperage from the battery with the main ON/OFF switch turned on and no load connected. To prevent battery discharge, turn the inverter off when you are not using it.
● Only connect the power inverter to a 12V battery or power supply.
● Do not let the inverter into sunlight directly, keep it in a cool environment.
● Don’t use the inverter with a product that draws a higher wattage the inverter can provide, as this may cause damage to the inverter and product.
