In an effort to reduce my dependency on grid power for my home, I am planning to install an off-grid, 48 volt MPP solar PIP LV5048 5KW 48V All-In-One solar power system. It will be powered by a 2000 watt ground mounted/fence mounted solar array using 20, 12 Volt, 100 watt Richsolar Polycrystalline solar panels. I plan on connecting the solar panels first in groups of 4 with a series connection so that each group will be 48 volts. Then I will be connecting the 48 volt groups, in parallel, to feed the power to the MPP System. I plan on using two 24 volt Battle Born batteries (connected in series) for storage. Also, I plan to set the priorities on the MPP to use solar power and battery power first and then to use grid power as needed. I have identified 5 circuits in my grid circuit breaker box that I would like to use the solar power for. I would very much appreciate any advice on the best way to connect these circuit to the MPP. Thanks.
