I've been on the same path of building and research. I'm kinda new to DC and solar but hopefully this helps. I'm not sure why basic questions with simpler answers get no response here, other than the fact that you need to do the work for your particular set of parameters.
All of these ratings and numbers (panels, inverters, wire/fuse size, etc.) are somewhat standardized but each system needs it's own "stats". In Will's book and many places on the internet you can get the tools needed to research and design a system that will work for your particular needs. Since I am installing in a relatively small vehicle where space is premium, I went with the traditional method of designing my system. Will also gives fast, lazy, and Armageddon scenarios...
Here's my basic method after boiling down all the info. Please correct me in any instance; I'm just learning.
Step 1: (LOAD) Figure out what you plan to power, for how long each day, and get ratings for all of these appliances in Watt-hours. Max amperage is also helpful for wire and fuse sizing. I also plan to test most of these appliances on the bench for real-world numbers during use.
Step 2: (STORE) Size the battery bank based on the daily watt-hour usage plus storage/backup. Try to at least double your used watt-hours in your battery bank. I'm starting "small" with 2400 watt-hours in a 24v/100Ah battery bank. Chemistry will also have an effect on your usable power and battery bank sizing.
Step3: (CHARGE) Size your panel array based on replenishing your daily usage and space you have available. Many factors here! Wiring gauges, series/parallel arrangements, overall voltages, etc. Once you get a handle on this, you can properly decide on a charge controller/inverter, which in my case was an all-in-one unit. Critical numbers are the max open voltage and short circuit amperage for the array.
Step4: (CONTROL) Select unit(s) based on all of the above; MPPT amperage and max solar voltage allowed, inverter size based on appliances, 12v/24v runs to power DC appliances, etc. Select the right unit(s).
Step 5: (BUILD) Design the system. Wiring paths, fuses and fuse blocks, breakers, buses, monitors/shunt, DC converters, etc, etc. All need to be accounted for.
Good luck!
